Date/Time: Wed, 22 Jan 2025 14:56:54 +0000
Spreadsheet and Bill Williams study
View Count: 1083
[2018-03-05 12:56:02] |
User316362 - Posts: 210 |
The Bill Williams study often places buy and sell signals one or two bars prior to the current one as an example. The spreadsheet seems to on update the current bar and shift down on new bar open. Thus, for Bill Williams study's the signals never show up in the spreadsheet on live data or back testing. Is there a way to "recalc" sheet on new bar or selected recalc? Else the only option is trading via ACSIL. |
[2018-03-05 18:26:00] |
We can solve this but we need to know specifically what study you are referring to. We need the full complete exact name.
[2018-03-05 18:30:23] |
it is "Bill Williams Fractals" Thanks |
[2018-03-05 18:40:03] |
OK we will solve this.
[2018-03-05 19:05:47] |
Thank you so much
[2018-09-28 14:17:57] |
any update on this?
[2018-09-28 18:36:50] |
This would have been done back in March 2018. We can see it was completed. Most likely it was done within 10 minutes of our response. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-28 18:37:01
[2018-10-02 20:35:02] |
thank you, I should have checked.
