Date/Time: Sat, 18 Jan 2025 19:38:49 +0000
DOM Question - Showing Chart Value in DOM for Cursor Location
View Count: 1403
[2018-03-05 05:20:58]
absorrel4 - Posts: 97
Please see the attached. Within the DOM you can see the "last price" within the chart at level 30187. I have my cursor within the DOM on the sell side at level 30165. Is there a way to have the 30165 text shown within the DOM like the last price does? If so, can the text color be changed so it is not the same as the "last price"? Finally, can the DOM cursor price be set so that it is always on top (so not to be partially or fully covered by the "last price" text)? Thanks...
imageDOM_LI.jpg / V - Attached On 2018-03-05 05:19:48 UTC - Size: 792.34 KB - 337 views
[2018-03-05 12:47:03]
Xfanman1 - Posts: 320
Use the Chart Value Tool with Crosshairs. This will highlight the cursor price and time to the color of your choice AND overwrite the last price when the cursor price is partially obscuring it.
Change these settings at Global Settings/Tool Settings/Chart Values. In my first post below you can see the current price is 6803.50 in white and red and the cursor price is displayed in Yellow at 6799.00
The link for the Chart Value Tools settings is here -->
Chart Drawing Tools: Chart Values/Crosshair
imageCursorHighlightPrice.PNG / V - Attached On 2018-03-05 12:46:43 UTC - Size: 46.57 KB - 318 views
imagePriceTimeBoxHighlight.PNG / V - Attached On 2018-03-05 12:46:50 UTC - Size: 33.25 KB - 295 views
[2018-03-05 18:44:00]
No, it is instead displayed at the top left of the chart.
You might want to change the Scale Increment:
Chart Scale and Scale Adjusting: Scale Increment (Scale Settings)
