Date/Time: Thu, 06 Feb 2025 19:08:10 +0000
[Programming Help] - Use tool example - horizontal line last price
View Count: 2228
[2018-03-04 23:25:01] |
User99934 - Posts: 227 |
How do I adjust color and thickness of this line? I cannot find any inputs to adjust.
[2018-03-05 17:51:02] |
Refer to the documentation here for the s_UseTool color and width member variables: Using Drawing Tools From an Advanced Custom Study: Drawing Tools and s_UseTool Member Descriptions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-03-05 18:33:14] |
I read the instruction. Among other places I went to analysis---> open custom studies files and cannot find/figure out what to modify.
[2018-03-06 04:07:53] |
That is a programming example. It is not meant for actual use by user as a study. Unless you are willing to work with it at the source code level, definitely do not use it or seek any help with it. It is not supported in this way. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-06 04:08:10
[2018-03-06 14:24:11] |
Thank you. I will look at later.
[2018-03-06 22:12:42] |
This is documented here: How to Build an Advanced Custom Study from Source Code: Searching for Source Code for Sierra Chart Built-In Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-03-07 04:41:02] |
@Ackin I put Line to last.dll and Line to last_64.dll into data directories and unable to see them. |
[2018-03-07 16:48:06] |
@Ackin Figured it out. Thank you. |
[2020-09-08 18:12:53] |
Hello, The attached DLLs were kindly done by Ackin. I see he is no longer on the SierraChart forum? The attached DLL simply makes an adjustable horizontal line at the last price. Can someone modify it so it works on Version 2162? Thanks! |
Private File Private File |
[2020-09-08 19:15:57] |
Ackin - Posts: 1865 |
You can register on my forum and there is a download + another 300 studies. info: https://www.sierrachart.com/UserControlPanel.php?page=StudyStore&SCDLLName=zyp_download_free |
[2020-09-09 12:54:23] |
User99934) access details sent, check your email Have a nice day |
