Date/Time: Sun, 19 Jan 2025 00:18:53 +0000
nonsence number at drawdown and runup in tradelog
View Count: 916
[2018-03-04 13:37:37] |
User30743 - Posts: 365 |
hello, how is it possible that in my tradelogg i have such a nonsensical number at drawdowns and runup columns? how will i repair it so that it will show the correct numbers
Date Time Of Last Edit: 2018-03-04 13:42:25
dd runup wrong.png / V - Attached On 2018-03-04 13:37:19 UTC - Size: 56 KB - 313 views nonsens dd.png / V - Attached On 2018-03-04 13:42:22 UTC - Size: 50.14 KB - 282 views |
[2018-03-06 03:48:18] |
This is the result of the High/Low Price During Positions both being 0. But the internal representation of those should be in a state which prevents the runup and drawdown calculations from even being done for a particular symbol. However, if they are actually exactly 0, not sure why that would happen. And in this case those runup and drawdown values clearly will be large. You need to just edit those fields for the order fills in the Trade Activity Log. Refer to: Trade Activity Log: Trade Activity Data Editing Menu Commands (Trade >> Trade Activity Log) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-06 03:49:16
