Date/Time: Sat, 26 Apr 2025 09:40:34 +0000
Number Bars Bid/Ask Difference minimum volume
View Count: 1676
[2018-03-03 18:26:56] |
User71961 - Posts: 144 |
For the following settings on a NumberBars chart: Column 1 Background Type = Ask Bid Difference Profile Column 1 Background Coloring Method = Based on Askvol/BidVol Percentage OR Based on Dominant AskVol BidVol to VolumeAtPrice Percentage Is there a "Minimum Volume Difference" setting to filter out prices, so that it will only consider for highlighting volumes where the difference is above a specified threshold (to filter out the noise)? For example, if the bid/ask volume for a price of 61.45 is 200 | 260, then the net volume was 60 bought at 61.45 inside that candle, and if that was the largest net volume bought in the candle, then that volume for that price would be fully highlighted. However, i only want the highlighting to occur if the net volume difference (bought or sold) is above a specified value (say, 150)...in which case, that 200 | 260 bid|ask price activity would have no highlighting at all (because the net difference of 60 was below my custom threshold of 150). Does this exist? And if not, can it be added? |
[2018-03-04 22:00:01] |
No, it does not exist. The closest that is available is: Numbers Bars: Bid/Ask Minimum Volume Compare Threshold Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-04 22:00:13
