Date/Time: Sun, 19 Jan 2025 00:14:32 +0000
hide and show a whole region in one
View Count: 1841
[2013-04-05 11:26:50] |
cross - Posts: 70 |
Is there a way to hide a whole Region in one instead of hiding all studies in them one-by-one? Thanks Date Time Of Last Edit: 2013-04-05 11:27:09
[2013-04-05 17:37:35] |
Yes. What you need to do is use Study Collections: http://www.sierrachart.com/index.php?l=doc/doc_StudyCollections.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-04-07 10:25:08] |
cross - Posts: 70 |
I found out that checking the Prompt to Remove Existing Studies makes it possible to add multiple Study Collections to a chart. However, adding Study Collections in different order messes up the Studies' cross references to each other inside the same Collection. When applying a Study Collection to a chart the references inside would be offsetted by the Study ID of the last one on the chart which after the Collection gets added. ( I am a new SC user so please forgive me for newbie questions. I am amazed of the SC's flexibility but that comes with complexity :D ) |
[2013-04-08 22:59:37] |
What you describe is true and there is not a simple solution to that when applying a Study Collection, to a chart with existing studies, when there are references between the studies of the applied study collection.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-08 23:00:07
[2018-03-08 06:24:25] |
User342238 - Posts: 44 |
Hi, I'm trying to remove a region from the chart. The indicator in the region is hidden and I want to reclaim the empty space that is open in the region. Is there a way to collapse or manually size the region?
[2018-03-08 21:14:01] |
The information for how to do this can be found here: Working With Charts: Chart Window and Regions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
