Date/Time: Sat, 18 Jan 2025 19:33:14 +0000
well-defined intraday TPOs
View Count: 641
[2018-03-01 22:11:53] |
User336964 - Posts: 29 |
Hi support, I have 2 questions. 1. In TPO study using "multiple profiles based on fixed time", I use 5 min as "Profile time period length" but I want that to be made up of 300-second TPOs instead of 5 one-minute TPOs. This helps in viewing a super defined profile (in terms of bell curve, exactness of POC, etc). Just like how a day's profile can be well defined when using one-minute TPOs instead of thirty-minute TPOs, I want to see a 5 minute candle in that way. How to attain this? 2. After adding TPO, I exported "bar and study data to text file". In the file, only OHLC, volume, bid-ask vol, etc are exported. I also want POC and actually all the data present in "chart values window". How? Thank You. |
[2018-03-01 22:33:28] |
1. This does not make sense to us. So basically you just want one period within the five-minute profile length. That is how we are reading what you wrote. 300 seconds is five minutes. So you can already do that now. 2. This is not supported. You can use the TPO Value Area Lines study on a standard chart to get the point of control: TPO Value Area Lines Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-01 22:34:11
[2018-03-01 22:46:40] |
1. But what we will do and has been asked about before is the ability to set the TPO subperiod in seconds so that you can go lower than 60 seconds/1 Minute.
