Date/Time: Sun, 24 Nov 2024 05:35:54 +0000
filter volume from the size of trade
View Count: 1454
[2013-09-30 13:58:13] |
Juriossoy - Posts: 11 |
hi your platform has the indicator which can filter volume from the size of trade on a timeline? |
[2013-09-30 16:24:34] |
Yes. Refer to Volume Filter in Chart Settings: http://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#VolumeFilterH Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-09-30 17:17:47] |
thanks!
