Date/Time: Sat, 18 Jan 2025 19:26:09 +0000
[Programming Help] - Trade Activity Log : entry/exit/max quantities are now double
View Count: 562
[2018-03-01 16:31:22] |
User877753 - Posts: 152 |
Hello, On the Trade Activity Log, the Entry / Exit / Max Quantities are double : for one contract in, the value is no more 1 but 1.000000 I guess this is connected with the change frome integer to double, but in fact, this is not really confortable when trading futures (I dont trade bitcoin or Forex). How can I change the format, to get back the integer format ? Thank you, Best regards, |
[2018-03-01 19:27:50] |
This will be solved in the next release.
