Date/Time: Sat, 18 Jan 2025 19:29:00 +0000
a chart with number bars
View Count: 718
[2018-03-01 14:51:33]
Glenn Infinity - Posts: 103
The text is set to "bid volume X ask volume". Is it possible to highlight only the highest bid volume and the highest ask volume within a bar?
[2018-03-01 21:32:06]
Right now it is not possible to highlight BOTH the Maximum Bid Volume and the Maximum Ask Volume. It is possible to do one or the other. You accomplish this by setting the following Inputs on the Numbers Bars study:
Highlight Maximum Value In: Column you want to Highlight On
Highlight Maximum/Minimum Value Based On: Choose either Bid Volume or Ask Volume
The documentation for these inputs can be found here:
Numbers Bars: Highlight Maximum Value In
and here:
Numbers Bars: Highlight Maximum/Minimum Value Based On
