Date/Time: Sat, 18 Jan 2025 19:20:50 +0000
SC is showing charts of 30 sec, 20 sec and 10 sec all the same thing
View Count: 2035
[2018-02-28 22:54:57] |
User271989 - Posts: 44 |
i was using seconds chart with no problems but today i switch to 30, 20 or 10 and they all looks like the 20 seconds chart. this is happening in my vps but i looked in my pc and it is normal how can i fix it? to have seconds chart what i do is add the custom period 1, 2, 3, etc and put 0-0-10, 0-0-20, etc Date Time Of Last Edit: 2018-02-28 23:17:25
Attachment Deleted. image (1).png / V - Attached On 2018-02-28 23:17:11 UTC - Size: 55.33 KB - 304 views image (2).png / V - Attached On 2018-02-28 23:17:19 UTC - Size: 53.75 KB - 326 views |
[2018-03-01 00:47:33] |
just tried "delete and download data" in 30 sec, 20 and 10 and does not works too...
[2018-03-01 21:14:31] |
Be sure the Intraday Storage Time Unit is set to 1 second or 1 tick. The documentation for this setting is found here: http://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#IntradayDataStorageTimeUnit Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-01 21:15:11
