Date/Time: Sat, 18 Jan 2025 19:27:06 +0000
black box over price scale
View Count: 1045
[2018-02-28 22:17:02] |
auggie - Posts: 45 |
I upgraded to 1705 and the current price on the right price scale is blacked out. How do I fix that? Thanks, Larry |
[2018-02-28 22:22:32] |
In Graphics Settings change the Last Trade Price Box Foreground color: Graphics Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-28 22:24:03
[2018-02-28 22:23:21] |
http://www.sierrachart.com/image.php?Image=1519856577220.png
[2018-02-28 22:25:17] |
Thank you!
[2018-03-01 12:06:20] |
Actually it worked once but then it keeps reverting back to black. I hit apply after changing the color to white but then after shutting down SC and restarting the black boxes are back. What to do?
[2018-03-01 20:01:10] |
Not sure why this is the case but this will not happen in the latest "Prerelease". At least not in the testing we did. Here are instructions to update: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-01 20:01:24
[2018-03-01 20:06:00] |
Thank you for fixing the bug! The new release works.
