Date/Time: Thu, 24 Sep 2026 06:54:22 +0000
[Programming Help] - ACSIL - WilliamsR
View Count: 1759
| [2018-02-28 20:58:34] |
| VaclavS - Posts: 21 |
Hello, Can you pls show to me ACSIL code for WilliamsR |
| [2018-02-28 22:51:54] |
| JoseyWales - Posts: 67 |
Here is the code for Williams %R, found in file ACS_Source\studies5.cpp SCSFExport scsf_WilliamsR(SCStudyInterfaceRef sc)
{ SCSubgraphRef PercentR = sc.Subgraph[0]; SCInputRef Length = sc.Input[3]; SCInputRef Invert = sc.Input[4]; SCInputRef InputDataHigh = sc.Input[5]; SCInputRef InputDataLow = sc.Input[6]; SCInputRef InputDataLast = sc.Input[7]; SCInputRef UpdateFlag = sc.Input[8]; if(sc.SetDefaults) { sc.GraphName = "Williams %R"; sc.GraphRegion= 1; sc.ValueFormat = 2; PercentR.Name = "%R"; PercentR.DrawZeros = true; PercentR.DrawStyle = DRAWSTYLE_LINE; PercentR.PrimaryColor = RGB(0,255,0); Length.Name = "Length"; Length.SetInt(10); Length.SetIntLimits(1,MAX_STUDY_LENGTH); Invert.Name = "Invert Output"; Invert.SetYesNo(1); InputDataHigh.Name = "Input Data for High"; InputDataHigh.SetInputDataIndex(SC_HIGH); InputDataLow.Name = "Input Data for Low"; InputDataLow.SetInputDataIndex(SC_LOW); InputDataLast.Name = "Input Data for Last"; InputDataLast.SetInputDataIndex(SC_LAST); UpdateFlag.SetInt(1); //update flag sc.AutoLoop = 1; //During development set this flag to 1, so the DLL can be modified. When development is completed, set it to 0 to improve performance. sc.FreeDLL = 0; return; } if (UpdateFlag.GetInt() == 0) { InputDataHigh.SetInputDataIndex(SC_HIGH); InputDataLow.SetInputDataIndex(SC_LOW); InputDataLast.SetInputDataIndex(SC_LAST); UpdateFlag.SetInt(1); } sc.DataStartIndex = Length.GetInt(); sc.WilliamsR( sc.BaseData[InputDataHigh.GetInputDataIndex()], sc.BaseData[InputDataLow.GetInputDataIndex()], sc.BaseData[InputDataLast.GetInputDataIndex()], PercentR, sc.Index, Length.GetInt() ); if (Invert.GetYesNo()) PercentR[sc.Index] *= -1; } |
| [2018-02-28 23:13:01] |
If you were asking about how the sc.WilliamsR() function operates, it calls WilliamsR2_S behind the scenes: float GetHighest(SCFloatArrayRef In, int StartIndex, int Length) { float High = -FLT_MAX; // Get the high from the last Length indexes in the In array for (int SrcIndex = StartIndex; SrcIndex > StartIndex - Length; --SrcIndex) { if (SrcIndex < 0 || SrcIndex >= In.GetArraySize()) continue; if (In[SrcIndex] > High) High = In[SrcIndex]; } return High; } float GetLowest(SCFloatArrayRef In, int StartIndex, int Length) { float Low = FLT_MAX; // Get the low from the last Length indexes in the In array for (int SrcIndex = StartIndex; SrcIndex > StartIndex - Length; --SrcIndex) { if (SrcIndex < 0 || SrcIndex >= In.GetArraySize()) continue; if (In[SrcIndex] < Low) Low = In[SrcIndex]; } return Low; } SCFloatArrayRef WilliamsR2_S(SCFloatArrayRef InputDataHigh, SCFloatArrayRef InputDataLow, SCFloatArrayRef InputDataLast, SCFloatArrayRef Out, int Index, int Length) { if(Index < Length) Out[Index]=0; else { float High = GetHighest(InputDataHigh,Index, Length); float Low = GetLowest(InputDataLow,Index,Length); Out[Index] = 100 * ( High-InputDataLast[Index]) / (High - Low); } return Out; } |
| [2018-03-01 21:58:45] |
For reference here is the relevant documentation: How to Build an Advanced Custom Study from Source Code: Searching for Source Code for Sierra Chart Built-In Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-01 21:58:54
