Date/Time: Wed, 16 Sep 2026 12:26:16 +0000
errors in your sample studies
View Count: 910
[2018-02-28 19:32:39]
Devil_On_WallStreet - Posts: 67
I started messing around with coding, and decided to start with looking at functions from your zig zag because it both outputs text as well as different values based on type... first 2 errors are on lines 1616 & 1726... you simple forgot to put in the "//" before the explanation.... after changing only those 2 things... a complete copy and paste, the compiled dll does not output text labels nor peak values like the actual zig zag study... How can I view a correct, complete example of this code?
[2018-02-28 19:43:22]
Just to clarify... I'm referring to the HH,HL,LL,LH labels that output values of 1,2,3,4...
[2018-02-28 22:15:32]
The code in that is provided with Sierra Chart in /ACS_Source is definitely fine. There cannot possibly be the problems you describe.
Also, you really have to provide the actual code you are referring to rather than just simply a line number. When we look at those line numbers in the studies7.cpp file which contains the zigzag study, we do not see what you are referring to.
Date Time Of Last Edit: 2018-02-28 22:17:10
[2018-02-28 22:41:18]
Apologies... first time looking at code, I thought that the code started near the input settings... found the peices of code above that began with the "void" added it and all was solved.
