Date/Time: Sat, 18 Jan 2025 19:40:21 +0000
Run ACSIL code on window focus
View Count: 797
[2018-02-28 19:31:36] |
aknsyu71@gmail - Posts: 54 |
Run the code one time but every time the window receives focus. Ive tried sc.ChartWindowIsActive but it runs the code many times. Many thanks |
[2018-02-28 22:01:09] |
The only way to do this is to use this member: ACSIL Interface Members - Variables and Arrays: sc.UpdateAlways And then you can check sc.ChartWindowIsActive to see if the chart is active. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
