Date/Time: Sat, 18 Jan 2025 19:27:19 +0000
Issue with Trading system base on color background
View Count: 577
[2018-02-28 14:10:47] |
User657944 - Posts: 173 |
I have an issue when I try to modify the visual indicator of the entry (std is point on low/high) to a arrov up o triangle up etc. simply it does not show anything only the point is working can you check please my version is 1705 and for the rst is working. thx |
[2018-02-28 18:12:15] |
Currently there is no support for other than the default Draw Styles (Point on High/Low) with this study.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-28 18:12:28
