Date/Time: Sun, 24 Nov 2024 05:33:54 +0000
Extra bars after close
View Count: 1338
[2013-09-29 23:33:06] |
User49270 - Posts: 48 |
Hi, I keep getting extra bars after Fridays close on my es chart. This week there were 3 extra bars after 16:00 which makes my VP and TPO studies inaccurate for Sunday. I'm using a 6 range chart. Thank you Howard |
[2013-09-30 20:31:08] |
Make sure your computer's clock is set correctly: Http://www.sierrachart.com/index.php?l=doc/helpdetails38.html Set the End Time in the Chart >> Chart Settings >>Session Times to 15:59:59 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-09-30 20:31:29
