Date/Time: Sat, 18 Jan 2025 19:37:29 +0000
Live data feed and programming of orders and positions
View Count: 615
[2018-02-28 13:54:32]
User431511 - Posts: 18
Hi, I'm looking to interface sierra charts with a non commercial charting software package to enable a live data feed which will generate positions and orders.
Originally we were looking at creating a unique charting tool (there's nothing like it on the market) within the Sierra environment but unfortunately is cant be done.
The feedback provided to Frederik Vink was that Sierra Charts always uses a fixed amount of space for each charting column.
The next best option is to link the data feed from Sierra charts via CQG with the non commercial software package which can create orders and positions in sierra charts.
To enable this, a program needs to be developed to allow the data feed from sierra charts to interface with the non commercial software package.
Can it be done?
If yes what are the programming parameters to ensure a successful live data link between both software programs.
Your valuable feedback would be appreciated, when convenient. Sample pic attached. Regards Robert
Date Time Of Last Edit: 2018-02-28 18:14:52
imageangle symmetrics daily chart.png / V - Attached On 2018-02-28 13:53:40 UTC - Size: 85.4 KB - 211 views
[2018-02-28 18:16:26]
We are familiar with this communication, and unfortunately this is the case. And this is not really something that is easily changed.
Can it be done?
What you want to use is the DTC Server in Sierra Chart:
Data and Trading Communications (DTC) Protocol Server
It will provide market data and you can also submit orders and get all of the related Order and Position updates.
Date Time Of Last Edit: 2018-02-28 18:17:47
