Date/Time: Sun, 24 Nov 2024 05:31:12 +0000
Add Zero Padding to Millisecond Times In Chart Values Bar
View Count: 1423
[2013-09-29 23:17:03] |
bfalk - Posts: 33 |
Currently there is no zero padding in the 'Chart Values' window nor the 'Chart Values' status bar (below the toolbar) for the millisecond part of time. A bar starting at 96ms for example, would currently show up as 14:00:00.96 rather than 14:00:00.096 -B Date Time Of Last Edit: 2013-09-29 23:17:17
[2013-09-30 03:41:54] |
We see and this does make sense. We will correct this.
