Date/Time: Sat, 18 Jan 2025 19:25:18 +0000
Sierra Chart Wine install?
View Count: 989
[2018-02-28 02:28:21] |
User509820 - Posts: 69 |
Hi, I have been able to get Sierra Charts installed on Mac. When I open and try to connect I keep getting a error code. "Failed to open configuration file when saving. Configuration not save. Error: Windows error code 3: Path not found." Any suggestion? Thanks |
[2018-02-28 03:16:59] |
Refer to: Error Messages When Opening Files Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-02-28 05:47:11] |
The page shows the error message but no solutions of how to fix it?
[2018-02-28 18:26:04] |
There are many solutions given. However looking at this more closely: 3: Path not found."
We really are not sure why you would have this. And we do not provide support for Wine. Our recommendation is to use Parallels instead. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
