Date/Time: Sat, 18 Jan 2025 19:45:35 +0000
[Programming Help] - Can't connect to Interactive Brokers
View Count: 1545
[2018-02-28 00:43:09] |
Walkingheadpro - Posts: 2 |
Below are the logs (all repetitive connection attempts are excluded). I am trying to connect SC to my Interactive Brokers data with no success. Everything is set up correctly with my TWS platform and on IB's end. I'm just having trouble entering the correct information in the Data/Trade settings window(As far as I know). I've included my TWS username and password in the service setting window and that's about it. Where do I enter my IB user id number - I have instance client ID set to 0 as all options provided don't match anything I'm aware of? Is there a section where I can enter the port number found in the API settings of the TWS platform? LOG: Reading Internal Order ID file. | 2018-02-27 13:37:50 Reading Trade Orders file. | 2018-02-27 13:37:50 Reading Trade Positions file. | 2018-02-27 13:37:50 Listening on UDP port 22904. | 2018-02-27 13:37:50 Software version: 1705 | 2018-02-27 13:37:50 Usage end date: 2018-03-09 | 2018-02-27 13:37:50 Enabled for: Advanced Features. | 2018-02-27 13:37:50 Enabled for: Advanced Features 2. | 2018-02-27 13:37:50 Enabled for: Sierra Chart Historical Data Service. | 2018-02-27 13:37:50 Allow Support for Sierra Chart Data Feeds is enabled. | 2018-02-27 13:37:50 Current selected Data/Trading service: SC Data - All Services | 2018-02-27 13:37:50 Chart Update Interval: 500 | 2018-02-27 13:37:50 Time Zone: -08:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2018-02-27 13:37:50 2018-02-27 13:37:49 Local computer time | 2018-02-27 13:37:50 2018-02-27 21:37:49 Local computer time in UTC | 2018-02-27 13:37:50 2018-02-27 13:37:49 Local computer time in SC Time Zone | 2018-02-27 13:37:50 2018-02-27 21:37:48 Server time in UTC | 2018-02-27 13:37:50 Local computer UTC time and Server UTC time difference: 1 seconds. | 2018-02-27 13:37:50 Program path: C:\SierraChart\ | 2018-02-27 13:37:50 Data Files path: C:\SierraChart\Data\ | 2018-02-27 13:37:50 OS Version Number: 10.0 | 2018-02-27 13:37:50 Locale Setting: C | 2018-02-27 13:37:50 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-02-27 15:55:08 Socket (308) | Creating socket. | 2018-02-27 15:55:08 Socket (308) | Connecting to IP: 127.0.0.1. | 2018-02-27 15:55:08 Socket (308) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-02-27 15:55:09 * Socket (308) | Initiating close of socket by core. | 2018-02-27 15:55:09 Interactive Brokers | Failed to connect to the data and trade server. | 2018-02-27 15:55:09 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-02-27 15:55:09 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-27 15:55:09 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-27 15:55:09 Socket (308) | Closed. | 2018-02-27 15:55:09 Interactive Brokers | Disconnected. | 2018-02-27 15:55:09 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-27 15:55:09 Starting TWS auto-login thread. | 2018-02-27 07:56:08 TWS auto-login thread ending. | 2018-02-27 07:56:08 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-02-27 15:57:09 Socket (311) | Creating socket. | 2018-02-27 15:57:09 Socket (311) | Connecting to IP: 127.0.0.1. | 2018-02-27 15:57:09 Socket (311) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-02-27 15:57:10 * Socket (311) | Initiating close of socket by core. | 2018-02-27 15:57:10 Interactive Brokers | Failed to connect to the data and trade server. | 2018-02-27 15:57:10 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-02-27 15:57:10 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-27 15:57:10 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-27 15:57:10 Socket (311) | Closed. | 2018-02-27 15:57:10 Interactive Brokers | Disconnected. | 2018-02-27 15:57:10 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-27 15:57:10 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-02-27 16:01:11 Socket (317) | Creating socket. | 2018-02-27 16:01:11 Socket (317) | Connecting to IP: 127.0.0.1. | 2018-02-27 16:01:11 Socket (317) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-02-27 16:01:12 * Socket (317) | Initiating close of socket by core. | 2018-02-27 16:01:12 Interactive Brokers | Failed to connect to the data and trade server. | 2018-02-27 16:01:12 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-02-27 16:01:12 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-27 16:01:12 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-27 16:01:12 Socket (317) | Closed. | 2018-02-27 16:01:12 Interactive Brokers | Disconnected. | 2018-02-27 16:01:12 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-27 16:01:12 |
