Date/Time: Sat, 18 Jan 2025 19:42:55 +0000
BuyExit / SellExit Question
View Count: 858
[2018-02-28 00:35:48] |
bala - Posts: 74 |
Here is the scenario: 1. I enter a market order (buy /sell) 2. I don't want to - no time - to set a stop or stop limit order (and no offset either) Question: 1. Is there an order type where I can exit a position based on offset in ticks I relation to my market order position? 2. If I use automated trading - THIS IS CRITICAL - can I run a program to EXIT only. I MANUALLY ENTER orders but use program to exit ( BuyExit / SellExit). In other words if MANUALLY ENTERED will the PositionData.PositionQuantity show the correct order quantitiy to exit aitomatically? Thanks |
[2018-02-28 18:02:04] |
1. Yes just use Attached Orders. Refer to: Attached Orders: Step-By-Step Instructions These can also be sent even after the original parent order is sent: Order Types: Send Attached Orders - Position/Price 2. Yes this is fully supported. Just use the Buy Exit and Sell Exit order actions with the automated trading system: Automated Trading Management: Buy Exit Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-28 18:02:42
