Date/Time: Sat, 18 Jan 2025 19:23:38 +0000
[User Discussion] - autotrading enable ?
View Count: 638
[2018-02-28 00:19:45] |
User20450 - Posts: 330 |
i have autotrader enabled - chart uncheck and it is still trading , is there another way to shut of just one chart with out shutting other off? thanks
Private File |
[2018-02-28 02:04:39] |
The auto trading must be occurring on another chart. It is not possible to disable auto trading from a chart and still have automated trading from that particular chart. We verified this. It is simply is not possible whatsoever.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-28 02:53:35
