Date/Time: Sun, 19 Jan 2025 15:15:05 +0000
[User Discussion] - Draw an Extended Rectangle/Line with text inside/label as default
View Count: 2033
[2018-02-27 23:18:53]
User252419 - Posts: 235
Is it possible to Draw an Extended Rectangle/Line with text inside/label as default?
Thank you
[2018-04-17 05:00:41]
User993113 - Posts: 74
I've already searched for this but could find this option only for horizontal line via Config Name (Copy Config Name To Text via Tools --> Tools Config --> Horizontal Line Config ); is it possibile to do the same with extended rectangles?
[2018-04-17 06:02:02]
There is no way to do this by default.
See the documentation here for a way to add text to certain drawing tools, including the Extending Rectangle and Line:
Chart Drawing Tools: Modify Text
