Date/Time: Sat, 18 Jan 2025 19:20:38 +0000
[Programming Help] - ACSIL 64-bit order quantities are now of a double type rather than integer type
View Count: 815
[2018-02-27 23:06:59] |
User553714 - Posts: 184 |
When I switch over to 64-bit SC will I be able to keep using Type int for quantity related variables in my studies and is this change purely handled internally by SC?
[2018-03-01 08:15:39] |
User79074 - Posts: 105 |
I would also like to know the answer to this question. Thank you
[2018-03-01 14:44:44] |
Yes of course you can still use an integer.
