Date/Time: Sat, 18 Jan 2025 19:31:01 +0000
COMMODITY CHANNEL INDEX
View Count: 672
[2018-02-27 23:05:54] |
User841161 - Posts: 232 |
IS THERE A WAY IN SIERRA TO COLOR AREAS OF THE CCI THAT ARE ABOVE THE 100 LINE AND BELOW THE 100 LINE, JUST LIKE IN THE ATTACHED CHART. THE RED AND GREEN TIPS. PREFER NOT TO COLOR WHOLE BACKGROUND JUST AREA INSIDE OF GRAPH.
Private File |
[2018-02-28 03:59:27] |
Not exactly like this. The closest that is available is to use the Fill to Zero draw styles: Chart Studies: Fill to Zero (ACSIL: DRAWSTYLE_FILL_TO_ZERO) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-28 04:00:04
