Date/Time: Sat, 18 Jan 2025 19:31:04 +0000
SC data feed
View Count: 646
[2018-02-27 20:32:06]
User401511 - Posts: 33
Not using the SC data feed at the moment. Trying to change my data feed back to interactive brokers but the box inside data feed services is greyed out and will not let me change it back so I'm stuck with historical data. I need help
[2018-02-27 23:08:01]
There should not be a problem with this. Are you referring to another instance of Sierra Chart started through File >> New Instance?
[2018-02-27 23:16:56]
Yes sorry it is another instance
[2018-02-28 02:50:18]
OK you need to make this change in the main instance of Sierra Chart.
Date Time Of Last Edit: 2018-02-28 02:50:26
