Date/Time: Sat, 18 Jan 2025 19:46:01 +0000
Detach Chartbook?
View Count: 987
[2018-02-27 18:06:10] |
User14266 - Posts: 225 |
Is it possible to detach a chartbook?
[2018-02-27 19:16:03] |
No. The only solution like this would be to use another instance: Using DTC Server for Data and Trading in Another Sierra Chart Instance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
