Date/Time: Sat, 18 Jan 2025 19:39:03 +0000
spreadsheet documentation?
View Count: 753
[2018-02-27 16:57:06] |
Devil_On_WallStreet - Posts: 67 |
is there any documentation explaining how to use the spreadsheet to make comparisons of values independent of bar count... examples would be... being able to compare zig zag cumulative volume only @ swing lows or highs... or being able to compare bar high/lows with an alert conditions v.s previous alert point value?
[2018-02-27 19:21:29] |
See if you can find something on this page we recently added: Spreadsheet Example Formulas and Usage If not, let us know and we will see if the author of that page can add something like what you are looking for. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-27 19:22:06
[2018-02-27 23:39:39] |
Sawtooth - Posts: 4154 |
There is an example here in post #3: Array formulas and auto-recalculate script |
