Date/Time: Sat, 18 Jan 2025 19:33:30 +0000
Background Alert
View Count: 993
[2018-02-27 01:41:13] |
User841161 - Posts: 232 |
In looking the Silver-Gold Chart, want alert to give me a signal when the slope is negative. Sometimes it seems like the trigger doesn't happen soon enough, it is delayed at times. For instance on 2-6 at 18:00 the slope is negative but background alert doesn't trigger until 2/7 at 2:00. The color background alert I am using is attached.
UploadImage.png / V - Attached On 2018-02-27 01:40:11 UTC - Size: 100 KB - 243 views Private File |
[2018-02-27 03:49:10] |
One thing to check is the Value Format settings. Refer to: Study/Chart Alerts And Scanning: The Effect of the Value Format on Identifier Values Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
