Date/Time: Sat, 18 Jan 2025 19:44:18 +0000
daily charts moved from one computer to another
View Count: 630
[2018-02-26 18:10:06] |
Glenn Infinity - Posts: 103 |
had a customer move some daily charts (.dly) to a new computer, the "to" date range is stuck on the day he moved them and he cannot change it in the chart settings. Did he fail to move a file from the old data folder? If so which file should he move?
[2018-02-27 20:18:57] |
There really is no reason to move these files. So long as the symbol of the chart is correct, we recommend at this point re-downloading the data in the chart. Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-02-27 20:34:30] |
this was the 1st thing suggested, he had already done that, any other ideas?
[2018-02-27 23:15:07] |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Fully re-download the data in the chart by going to the chart and selecting Edit >>Delete All Data and Download. After about a minute provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
