Date/Time: Sat, 18 Jan 2025 19:41:40 +0000
Sierra Chart Wine-MacbookPro Problem:Button Images
View Count: 1219
[2018-02-26 17:21:05] |
Proffiik - Posts: 4 |
Hello, I need to help with my problem. I am running Sierra Chart through Wine on the Macbook Pro. Everything works great just I have issue with my Control Bar buttons. I can't see the pictures of buttons. I see just numbers. In my Message Log I see: Cannot load control bar button image from location C:\Sierrachart\Graphics\Buttons\Button_32.bmp | 2018-02-21 22:39:36 * Do you know how to fix this problem ? Thanks, |
Attachment Deleted. Control Bar Buttons problem.png / V - Attached On 2018-02-26 17:17:51 UTC - Size: 833.71 KB - 486 views |
[2018-02-26 18:39:20] |
When you go to this folder: C:\Sierrachart\Graphics\Buttons\ Do you see the BMP image files there? One thing that we recommend doing is to change the Properties for those buttons which just display a number and set them to text rather than using the default image. Refer to: Control Bar: Control Bar Button Properties Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-02-26 20:56:07] |
Thank you for help. In the file C:\Sierrachart\Graphics\Buttons\. I can see the Buttons there. Maybe if you send me the Buttons images I can try to replace it. If it's possible please send it to v.profant95@gmail.com. Thank you. And your recommendation works. I can replace number for text. |
Buttons.png / V - Attached On 2018-02-26 20:53:21 UTC - Size: 238.86 KB - 387 views |
[2018-02-27 03:57:33] |
Sierra Chart - Max - Posts: 5779 |
The Buttons are located here: https://www.sierrachart.com/downloads/Common1692/Graphics/Buttons/AllButtons.zip Sierra Chart Support |
