Date/Time: Sat, 18 Jan 2025 19:20:14 +0000
Point and Figure Trend Lines
View Count: 1195
[2018-02-26 12:32:55]
User794190 - Posts: 26
How do I draw standard point and figure trend lines (which are always at a 45 degree angle)?
Another way to ask the same question -- is there a way to draw trend lines at specified angles?
I checked the documentation under line, ray, point & figure trend lines -- but couldn't find anything. Thanks.
[2018-02-26 21:44:08]
John - SC Support - Posts: 37327
There has been a new option added to the Line and Ray Drawing tools to allow for the drawing to be done at a specific angle. You can find the documentation for how to do this here:
Chart Drawing Tools: Drawing a Line with a Specific Angle
Date Time Of Last Edit: 2018-02-27 20:17:11
