Date/Time: Sat, 18 Jan 2025 19:44:56 +0000
UserContributedStudies -> 64bit
View Count: 1859
[2018-02-26 10:37:26]
tobi - Posts: 351
There has been a UserContributedStudies.dll that contained a bunch of studies.
One Study out of this collection called "Average Range" I've been using for a long time. Here one can choose whether the last bar will be used in the calculation or not.
Could you please add the Average Range study into the SierraChartStudies_64.dll or provied a 64 bit version of the UserContributedStudies.dll.
imageAverage Range.png / V - Attached On 2018-02-26 10:31:07 UTC - Size: 39.79 KB - 423 views
Private File
[2018-02-27 03:54:28]
We will do both.
[2018-02-27 04:58:04]
tobi - Posts: 351
When will this be available?
[2018-02-27 23:57:53]
Just give us a couple of weeks.
[2018-02-28 03:30:45]
tobi - Posts: 351
Please send / provide the cpp-file of the UserContributedStudies or just the Average Range indicator and I will build the 64-bit-dll myself.
Please understand that this indicator is part of my daily use of the chartbooks and I want to get done with the 64-bit conversion process.
[2018-02-28 14:01:50]
JoseyWales - Posts: 67
Here is UserContributedStudies_64.dll that I've compiled to use with 64bit Sierra Chart for the time being. I'd recommend deleting this file and update Sierra Chart through the downloader/installer when the official version is released.
Date Time Of Last Edit: 2018-02-28 14:03:26
attachmentUserContributedStudies_64.dll - Attached On 2018-02-28 13:50:40 UTC - Size: 1.95 MB - 464 views
[2018-02-28 19:25:29]
You can accomplish the Average Range just by using the Bar Difference study and basing the Moving Average on it.
And displacing it forward by one bar. Attached is the Study Collection.
Here are the instructions to use it:
Study Collections: Using a Study Collection Provided by Sierra Chart Support
attachmentAverage_Range.StdyCollct - Attached On 2018-02-28 19:24:56 UTC - Size: 18.7 KB - 472 views
[2018-02-28 20:23:04]
tobi - Posts: 351
Thank you very much Josey.
Working perfect as before :-)
[2018-02-28 20:26:13]
You're welcome
[2018-02-28 21:00:26]
NRGTrader - Posts: 351
Averse to downloading .dll files that we have no way of verifying validity/source (i.e., virus issues) though not implying you would do anything nefarious. Thanks though.
Still waiting for SierraChart Support to update.
[2018-03-05 15:22:46]
User624476 - Posts: 33
I'm eagerly waiting for this as well. Thanks.
