Date/Time: Sat, 18 Jan 2025 19:22:03 +0000
spread sheet realtime data problem
View Count: 797
[2018-02-26 02:10:13] |
User63632 - Posts: 43 |
Spread sheet..Real-time data is working with March Bond contracts, but will not update after adding June Bond contract. Although I am able to chart March Bonds. Please advise Thank you |
[2018-02-26 18:30:57] |
What if you change that symbol in the exact same cell to the March symbol, does it then update in real time?
[2018-02-26 19:41:22] |
Resolved..thank you
[2018-02-27 01:49:23] |
OK good the other thing we were to recommend is just to reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-02-27 15:45:21] |
Yep,reconnecting solved the issue..thanks
