Date/Time: Sun, 24 Nov 2024 06:10:31 +0000
volume profile
View Count: 1615
[2013-09-29 13:49:21] |
AKR - Posts: 523 |
is it possible to set the volume profile in a way that I can see a rectangle around the area I drew it for? is it possible - like for Poc and VA - to draw the highs and lows of the drawn profile? |
[2013-09-29 20:04:52] |
Zosimus - Posts: 345 |
Yes to both, Go to the settings of the Volume Profile. Choose "Yes" for "Draw Profile Enclosing Bars Outline" Choose "Both - Extend From Peak/Valley" for "Draw Peaks and Valleys" Choose "Yes" for "Include High/Low in Peaks and Valleys" If you you only want to see lines for the High and Low of the profile and don't want have lines for the other peaks and Valleys within the profile enter a high number (something like 200 will most likely do) for the "Peaks and Valleys Sensitivity". |
[2013-10-01 02:55:03] |
For the Point of Control and Value Area for Volume Profiles, you can enable highlighting or lines for those. Here is the documentation for this: http://www.sierrachart.com/index.php?l=doc/doc_VolumeByPrice.html#Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
