Date/Time: Sat, 18 Jan 2025 13:02:09 +0000
Quotes different for 1m vs. 30m and DOM
View Count: 622
[2018-02-26 01:19:09] |
BenG07410 - Posts: 2 |
My quotes on the 1m chart are different than the DOM and the 30m chart. Basically, they are just wrong. Can't get it to be correct even when reloading, etc.
[2018-02-26 01:49:41] |
Post an image of the 1 minute chart: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image And post an image of the 30 minute chart. Follow those instructions. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-26 01:49:50
[2018-02-26 02:04:13] |
I was in a hurry, and the only thing that worked was to just delete the chart and build a new one. It seems to be updating properly now.
