Date/Time: Sat, 18 Jan 2025 19:43:35 +0000
Plotting a subgraph value +/- X points ...possible?
View Count: 759
[2018-02-25 20:50:09]
patrader - Posts: 92
I'd like to plot or display as text a subgraph value (e.g. the Bollinger band's upper line value) +/- a fixed number of points. If the value of the ES Bollinger band's upper line is 2747.00 and I set a value of +2 points somewhere, then I'd like to see the number 2749.00 displayed as a custom text or a plot on the chart. If I set a value of -2 points somewhere then I'd like to see the number 2745.00 displayed as a custom test or plot on the chart. Can I do this? If so, which study or combination of studies should I use?
[2018-02-26 18:15:14]
Full documentation for this is here:
Using the Basic Arithmetic Studies
