Date/Time: Mon, 28 Sep 2026 00:02:23 +0000
[Programming Help] - ACSIL - Creating a new directory
View Count: 1179
| [2018-02-25 20:23:39] |
| Zosimus - Posts: 345 |
What is the way to create a new folder/directory from an ACSIL code? At the moment I use the Windows API CreateDirectory() function but I'm getting comiling errors. The code I use is: CreateDirectory(L"\\LV3_Folder", NULL);
the window API is included of course. The compiling error - cannot convert 'const wchar_t*' to 'LPCSTR {aka const char*}' for argument '1' to 'WINBOOL CreateDirectoryA(LPCSTR, LPSECURITY_ATTRIBUTES)' CreateDirectory(L"\\LV3_Folder", NULL); |
| [2018-02-25 23:31:13] |
You need to remove the L in front of the text string unless you call CreateDirectoryW instead.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-25 23:31:53
| [2018-02-26 00:28:00] |
Yes, this solved the compiling error and the build succeeded but no new directory is created when I run the dll. (the dll itself works properly so I see no reason for the createdirectory() not to work). using CreateDirectory("\\LV3_Folder", NULL); I expect to see a "LV3_Folder" directory in the data folder.
