Date/Time: Sun, 24 Nov 2024 05:35:33 +0000
Rpl not working and data query
View Count: 1427
[2013-09-28 10:47:37]
User92573 - Posts: 530
Dear Support,
I have two short questions.
1) I have SC v1028 loaded and when I select 'Rpl' nothing happens.
I also have v1013 on my test pc which I have been using to trial the program and run through ACSIL which works fine.
2) The log shows SC is trying to download data from FXCM when I open a Chartbook based on my own 'Historical scid' data - which follows my own naming convention. After an attempt to download 93 days (FXCM SC default setting) it closes the socket.
Why is it trying to download additional data to an scid file created from a fixed CSV data file? Can I instruct SC not to 'go out' and update certain chartbooks/charts based on certain data?
Many thanks
Paul H
Private File
[2013-09-28 21:52:01]
1. Select Window >> Reset Windows.
2. Enable Chart >> Chart Settings >> Advanced Settings >> Disable Data File Updating.
[2013-09-30 08:16:01]
What an excellent support service.
Thank you so much for the prompt response to both questions.
