Date/Time: Sat, 18 Jan 2025 19:29:54 +0000
Candle Stick Charts
View Count: 1207
[2018-02-24 17:11:04] |
User436838 - Posts: 3 |
I am mainly interested in being able to look at a live, real time candlestick chart in color of the stock I am trading. Is that a function that is included?
[2018-02-24 17:44:51] |
If I connect this with my broker, I assume I have to give my username and password for the broker account? Very reluctant to do that.....tell me why I shouldn't be please.
[2018-02-26 04:20:27] |
Refer to:Real-Time Data If I connect this with my broker, I assume I have to give my username and password for the broker account? Very reluctant to do that.....tell me why I shouldn't be please. Yes but this is only held within Sierra Chart on your computer in an encrypted format. But who is your broker? If it is Interactive Brokers you do not have to specify the username or password.
[2018-02-26 12:42:16] |
My broker is TD Ameritrade
[2018-02-26 18:35:57] |
TD Ameritrade is supported. Refer to: https://www.sierrachart.com/index.php?page=doc/AmeriTrade.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
