Date/Time: Sat, 18 Jan 2025 13:10:55 +0000
Add Shortcut to Add Custom Study Button
View Count: 1018
[2018-02-24 11:10:53] |
JoseyWales - Posts: 67 |
Would you consider adding a shortcut to the Add Custom Study Button on the Chart Studies dialog? Many of the other buttons have shortcuts by holding down the Alt key, even including rarely used buttons such as the Delete study collection button(Alt+t) and the Help button(Alt+h). I use many custom studies and would like to create a macro (F6 + Alt+Key) on one of my mouse buttons to go directly to the Add Custom Study dialog, I just require the Add Custom Studies button to have an associated Alt+Key shortcut. |
[2018-02-25 07:14:32] |
Yes we can do this.
