Date/Time: Sat, 18 Jan 2025 13:16:07 +0000
[User Discussion] - second instance questions
View Count: 1540
[2018-02-24 02:17:50] |
User98657 - Posts: 329 |
I know SC is not able to utilize multi core processors on one instance. If i use File>>New Instance, will the calculations within the sub instance be routed through the same thread(s)/core as the main instance? (in which case i would not gain any performance increase) if so, can i install a second installation of SC and call that second installation to help spread the load across a newer multi core processor? I have one transact futures account, and i pay for my own license to SC (I don't use the transact provided version). Tried to find support on the board, but didn't find what i was looking for, but feel free to point me to anything that exists. |
[2018-02-24 03:34:24] |
Refer to: Performance And: Using DTC Server for Data and Trading in Another Sierra Chart Instance: Using DTC Server for Data and Trading in Another Sierra Chart Instance Your questions are answered in both of these places. A separate instance always runs as a separate process and will take advantage of additional cores. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-02-24 22:49:18] |
jenda3 - Posts: 21 |
Hi, it is possible to use thread(s)/core from sub-instance to increase performance for BackTest in main instance. Or use thread(s)/core from main instance to increase performance in sub-instance? If yes, then how? Thank you. |
