Date/Time: Sat, 18 Jan 2025 13:18:36 +0000
Bitmex data feed stuck in a connection loop
View Count: 902
[2018-02-24 00:25:02] |
User633508 - Posts: 2 |
A connection to Bitmex Trading Direct is currently failing repeatedly with "Waiting to reconnect." I'm able to login to their WebUI, and the SC feed was working last night. Thanks! |
[2018-02-24 00:35:39] |
Provide a copy of the Message Log by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-02-24 01:25:42] |
I recreated my API key and everything's sorted now. Thanks! Should the issue arise again, I'll send the logs over. Date Time Of Last Edit: 2018-02-24 01:26:25
