Date/Time: Sat, 18 Jan 2025 13:03:18 +0000
Import Data
View Count: 853
[2018-02-23 19:42:19] |
User39772 - Posts: 311 |
When I import data a brand new chart window opens. How can I import data into an existing chart window with several indicators and settings to avoid that I have to manually make all settings in the new chart window ? |
[2018-02-23 23:35:17] |
After you import the data, what you then need to do is close that new chart and then duplicate the existing chart as explained here: http://www.sierrachart.com/index.php?page=doc/UsingChartTemplates.php#DuplicatingCharts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
