Date/Time: Sat, 18 Jan 2025 18:27:51 +0000
64 bit version and Transact
View Count: 1417
[2018-02-23 11:31:00] |
Outlander - Posts: 91 |
The 64 bit version seems not to work with Transact version of Sierra. It only starts the 32 bit version. Regards Outlander
[2018-02-23 11:36:00] |
Now that you mention this, this does make sense. We have to discuss this with them. But we are not going to contact them about it for two weeks until we are certain everything is fine with the 64-bit version.
[2018-02-23 11:44:06] |
Actually there is something you can do very easily on your side to make this work. Go to the Sierra Chart installation folder for the TransAct installation of Sierra Chart and delete SierraChart.exe. Then rename SierraChart_64.exe to SierraChart.exe. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-02-23 11:47:10] |
And considering all the problems that will definitely arise support wise with the 64-bit version, our advice to TransAct is to not adopt the 64 bit version for probably about 3-4 months from now. Perhaps even six months to a year would be better. Neither us or them need to deal with the consequences of all of the custom study problems that is going to arise. In general, there is not a practical need to use it. There simply is no practical benefit for the vast majority of users. The idea that Sierra Chart is so much better and faster, largely is just not true. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-23 11:52:02
