Date/Time: Sat, 18 Jan 2025 18:29:58 +0000
Custom Studies Automated Distribution after the 64bit Sierra release
View Count: 756
[2018-02-23 10:13:51] |
ticinotrader - Posts: 397 |
Dear Support, You mentioned in the 64bit related support thread, that any custom studies should be rebuilt with the new version(s). Can you please let me know if we need to provide you separate 32 and 64 bit version for automated distribution also? Will there be a separate license management (Allowed users) list for the two (32/64bit) versions? Thanks for the answer in anticipation! |
[2018-02-23 10:20:41] |
Can you please let me know if we need to provide you separate 32 and 64 bit version for automated distribution also? Will there be a separate license management (Allowed users) list for the two (32/64bit) versions? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-23 10:20:59
[2018-02-23 10:34:25] |
Last question: Should we use different naming format for the 32 bit and 64 bit before providing the dll to you to differentiate between them? Like Custom_Study_Name64.dll or Custom_Study_Name32.dll? Or the name should be the same and we need to indicate the version when sending the file to you? Thank you. |
[2018-02-23 10:43:56] |
This post here explains the format: Sierra Chart 64 Bit Version Plan Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
