Date/Time: Sun, 24 Nov 2024 05:36:55 +0000
request: grid for charts
View Count: 1366
[2013-09-27 23:03:03] |
4646ed - Posts: 230 |
you should create a grid for charts within a chartbook. The horizontal and vertical tile tools don't work very well in many cases. One of the problems is monitors come in different shapes and sizes and resolutions; another is that I (and probably many other people) am (are) always shifting different charts around experimenting with different numbers of charts within a window, different time frames, different studies, different sizes, different currencies -- and without a somewhat customizable snap-in grid to put them in I have to size and place many of them by hand -- which is a colossal waste of my time. (And yes I know the trick where you select them in reverse order to get the order you want; and the one where you resize the SC window before you tile horizontally/vertically -- these are still too roundabout and time-consuming). A (somewhat) size-and-number-of-tile customizable snap-in grid (that you could turn on/off) that we could just drop them into in whichever order we see fit would (I feel) make your software MUCH more practical and efficient to use. ALSO you could add some kind of sort function, e.g. by symbol, or time-period, or even type of studies, etc. Since you are so good at consistently improving it in other areas, I think that THIS way would increase its ease of use immeasurably. AND, I don't think any of your competitors have something like this... Date Time Of Last Edit: 2013-09-27 23:14:29
