Date/Time: Sun, 24 Nov 2024 05:24:41 +0000
[User Discussion] - Quantity Buttons Highlight on Trade Window
View Count: 1364
[2013-09-27 21:17:12] |
9baller - Posts: 38 |
Since migrating from NT I have made a few position sizing mistakes...I like the the ability to change the quantity with the radio buttons...but I was wondering if we could have an option installed that would highlighted the current quantity selected to a different color other than having the radio buttons the same color... IE....keep the option to change the radio buttons to whatever color you wish...but add the option of changing the selected quantity to another color if desired.... just a suggestion...may help others eliminate mental errors as well |
[2013-10-01 07:41:32] |
We will see about this later on.
