Date/Time: Sat, 18 Jan 2025 13:00:22 +0000
Momentum Indicator
View Count: 2170
[2018-02-22 18:52:23] |
User443598 - Posts: 5 |
Im using the Momentum indicator and Im trying to figure out how to configure it so the midline is 0 while the Momentum line weaves over it. The NT7 Momentum has a 0 midline and not 100 like SC. Any help is much appreciated. |
[2018-02-22 21:24:53] |
jsoviero - Posts: 84 |
Yes agree, in order to effectively use the auto coloring +or- we need the default 100 to be reset to ZERO. Thank you. |
[2018-02-26 04:14:22] |
You need to use this particular study: Rate of Change - Points Also these studies are so point-blank simple, you can always create these yourself. Like by using the Spreadsheet Formula study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-26 04:14:44
